Sloppy fit of bevelled mirrors in swept frames
Recently I made up a lot of bevelled mirrors in swept frames. I say that they are a sloppy fit is and understatement, as the the rebate size of the frames is easily 6mm larger that the mirrors. Of course if you were framing a canvas, this would be a lot better than being too small.
Since I don't like sloppy off-centre bevels havin looked at imported mirrors in discount shops they usually look reasonably on-centre, I therefore line the frames with strips of mountboard which is not an ideal answer. So does anyone else do anything similar, or do you ignore the off-centre effect?
Hi bigred,bigred wrote:How about using a good silicone sealant?![]()
Place the swept frame on it's face, mirror in place and fill around the gap inside the frame with the sealant and allow to dry (24 hours)
I think I prefer the mountboard strips as I can have it assembled, taped, strung and ready for sale in 10 minutes.
I was just looking for an easier way as the bit of mountboard can get in the way of the backing boards at times.
Why/how?Not your average framer wrote: the bit of mountboard can get in the way of the backing boards at times.
If the mirror is 4mm thick then make your strips 4mm thick also - everything is flush - pin and seal as normal.
Or ..... stick the mirror central on to the backing board - with whatever adhesive - this (on reflection) is no conservation job. Add some ATG for good measure, just so's you don't have to worry about lying it all flat to go off.
I'd still make the gap flush anyway though.
Hi John,Roboframer wrote:If the mirror is 4mm thick then make your strips 4mm thick also - everything is flush - pin and seal as normal.
The mirror is not 4mm thick in the rebate due to the 20mm wide bevel, so the mount board sticks out further anyway. Also the thinner you cut the mountboard the less likely that it will stay flat and striaght.
I have not done this, but I had though about cutting strips the full depth of the rebate and stapling it in place. When taped up these strips would completely hidden, however the framers points would go through the mountboard strips and then into the frame moulding, which I think could well reduce the penetration of the points into the moulding.
Having said that, I have seen the work of others with the rebates lined with 2 ply mountboard and with the framers points through the mountboard.
I use quite a lot of cork tiles for sapcing purposes. Cover the back of the tile with double-stick tape and slice it into 10mm strips. You can then chop little bits off and fix them inside the rebate. Good for holding oils on panels in place where you don't want the rebate to encroach too far into the painting. Cork has a nice 'give' to it. Works great for mirrors to stop them rattling about in the frame. Also makes good frame bumpers.
And it's cheap.
And it's cheap.
- Interests: 4 or 5 ...
thats pretty much what I do.markw wrote:few dabs of hot melt glue will hold the mirror in place - It takes seconds to apply and is very effective.
still on subject, have you noticed that some of the swept frames are slightly oversize, particularly the chinese and mexican ones (I understand this is deliberate)
whilst some of the bevelled mirrors can be slightly under size.
